Quoting tektic:
Oh, ok. Didn't know that. Thanks.
If you ask some of the UK/EU guys they should be able to pull them off a base Galant. If not, I understand DSM washer bottles are very similar and simply require some new holes drilled for mounting bolts. You probably don't need one though right? You just want to remove that plug.
Quoting iceman69510:
And you a police officer, tsk tsk tsk.
Actually I have no idea what the law is on meth injection over here. I bet (the way things are at present) that it will be illegal, irrespective of where the reservoir is placed. I'm assuming it is either (a) illegal or (b) considered inadvisable to place the meth reservoir under the hood.
If you are running straight meth, I think that it probably would be silly/reckless. If you are running a 50/50 water/meth mix then technically it shouldn't make any difference to having a regular washer reservoir under the hood since many windscreen washer fluids have up to a 50% concentration of meth/alcohol. Of course in our scenario it is plumbed into the engine but that side of things is there wherever you place the reservoir.
But yeah, you caught me Iceman. Given the way regulations are going over here, I figured if I plumbed in the entire headlight washer system (I pulled it from my base Galant), and plumbed the external feed carefully, it would probably go unnoticed. A tank in the trunk is almost certainly going to raise eyebrows and questions which equals FAILURE!
